Re: What kind of body is this?
do not recognize that particular body. Biddle and Smart?
----- Original Message -----
questions
Sheldon, Aaron,
Were you able to remove the cowl vent assembly?
Looking at mine under the dash I saw no screw mounts or way to remove it. I'm
trying to unfreeze mine now and find a repro lever as mine is broken.
Your
experience is vaulable.
Thanks
Jack
--- In HudsonSuperSix16-29@yahoogroups.com,
srody53@... wrote:
> Hi Aaron,
> Regarding the 29
Cowl vent, there is no screen as the later model Hudsons
> have, It was
not invented yet.. My car has an apparently orginal outer black
rubber gasket.
> This seems to keep level of the vent in the closed
position correct. There
> is no inner gasket. The drain hose goes down
into the interior of the car and
> then back thru the firewall to the
engine compartment then turning sharply
> straight down approxmately 10
inches. My hose ends near a place where an
> electricial wire goes thru
the firewall. I suggest making the hose longer. Yes the
> vent opens
directly into the cab.
> If you need a pic let me know.
> Hudsonly
> Sheldon Rody
> 29 Hudson
Victoria
************************************** See what's new at http://www.aol.com
