Re: Ivans Hudson
Attachments :
Ivan, This was such a great picture of your car I just had to clean it up for you. It's a low resolution picture to begin with but it cleaned up OK. Keep the prints below 5x7 and it should be fine. I removed the lines in the parking lot as well as reflections in the doors. If anyone else is interested in some photo touch-ups, let me know. I've been doing this stuff for a while now. Ted Ringold I have attached the "fixed" and original versions of the picture for you to compare. There is a little light on the ground in front of the front tire. I believe this is from a reflection off of the headlight above - so I left it in. Cheers.
--- On Thu, 5/13/10, Ivan Zaremba <ivanz62@comcast.net> wrote: |
Subject: Re: [HSS] Marvel Carb help
To: "Super Six Group" <HudsonSuperSix16-29@yahoogroups.com>
Date: Thursday, May 13, 2010, 12:44 PMPaul and Dave,
Thanks so much for your quick help. The email for Meadows is not configured correctly as it has no@ to separate out the domain name. I guessed and added the @. It didnt get kicked back.
You might reply with a corrected email for the record.
Attached is a picture of the car taken last Sunday on my first local drive.
Cheers,
Ivan
