Re: Clutch swap
Hi Geoff
Thanks for the advice on the
carburetors.
carburetors.
I have another question. I am considering
fitting a 29 clutch and flywheel assy to the 25 as I do not feel up to the
recorking job just now and want to take advantage of the remaining good
weather. I believe that you did this for Paul ONiel and would appreciate
any tips you could give me.
Obviously a splined input shaft, proper throwout
etc are required but fortunately I have a good supply of these. I will
probably use a complete 29 gearbox as I have one in very good
order.
order.
The 29 flywheel I have has some rust pits on the
friction surface which I can machine off/. This will probably require the
removal of about .020 of the working surface. Should I also remove the
same amount from the pressure plate mounting flange of the flywheel in order to
retain the correct relationship between friction surfaces?
Will a turned surface be OK on the flywheel or
should I have it ground? I can use carbide inserts and a very fine
feed.
feed.
Thanks
Karl
