Re: Parts available/wanted
Hi All
For Sale
We have many 25H Coach parts available. We
bought a car sight unseen which had been in a garage fire and have decided to
part it out. This was a restored or very good car prior to the
fire.
fire.
All body panels are available. They are
mostly very straight with minimal rust. Do not know if the heat has taken
the temper out.
the temper out.
Motor is free and .030 over. Head is low
compression. Accessories are shot. Water manifold is home
made.
made.
No interior whatsoever.
Hood and rad shell look good. Radiator
shot
shot
Wheels and rims are good (tires did not totally
burn off)
burn off)
Axles, springs, etc
Original complete exhaust system.
Throttle and spark gears from bottom of steering
box.
box.
Good frame
Many 29 parts. Headlights, some door handles,
sidelights and brackets, cowl ventilator levers, heads, blocks, rods, valves
crankcases, bumpers, luggage racks etc. Sorry no robe rail brackets or
tail lights.
tail lights.
Wanted:
Good hood or just the sides for 23
Hudson.
Hudson.
Amp meter for 23 Hudson (Delco
ignition)
ignition)
Delco distributor for 1916/22. Caps and
rotors would be a bonus
Seat frame for 28/29 coupe.
Steering wheel for 28H
Instrument cluster for 28H
Headlight staunchions for 28H
Rebuildable or good wire wheels for
27/28H
27/28H
Lower windscreen frame for 22/23 Essex
touring.
touring.
Amp meter for Essex (Bosch, probably the same as
Hudson)
Hudson)
Wheel rim (21") from 24/26 Essex 6
24" 1918/23 Essex 4 Wheels, rims, etc
Any Essex 4 mechanical parts.
Karl Hamson, karlh@shaw.ca, home 250 629 6119, cell 250 539
0014.
0014.
We are in British Columbia, Canada
