Cylinder block
Hi, I've had a similar problem with a 1920 block with pin holes in the cylinder walls. Getting a replacement block here in the UK was not possible, but you may be luckier Stateside ,even then you have go guarantee that it will be in good condition. I had a set of cylinder liners manufactured, bored out the block to take the liners, pressed in with ceramic sealant and then bored out to take the original pistons. Sealed top and bottom they have remained watertight. The liners cost me about $150 each here in the UK. Hope this helps.
Maldwyn Jones
