Pulling and Pusher Gears
Hello all, Time been ages... I'll get to the point I have a gear pulling problem I'm breaking down a straight 8 and I need help pulling the front gear without damaging it. The shop book calls for a J-471 puller and J-483 pusher any thoughts where I can find these or other means of removal and replacement.
Thank To All,
Dumb OX
Thank To All,
Dumb OX
Ox, Try going to your local NAPA store and ask for a Bearing Splitter tool. It actually has two halves which can get into tight areas to pull bearings out. In addition to this tool, you will need a cross arm puller to attach to the bearing splitter to get the pulling action. Most US made pullers{the quality stuff} is made by OTC in either Michigan or Minnesota. Good luck0
Hi.---I use a heavy duty 2 jaw puller on these gears & have never had a problem getting them off. Good Luck.0
