(no subject)
Hi Hudson Members,
In my 15 Hudson I
use Luces Hub oil. It works very well and in cold weather you can
still shift the transmission.
Also it stop my transmission for leaking a lot of gear
oil. With straight cut gears it needs a heavy oil to take up most
of the shock load. I use in the rear end too. Mine
29 is not on the road yet and I will use in this car too.
I also have it in the rear end of my 72 International
Travelall which I use to pull my trailer with my Hudson behind.
I have use this for many years with no problem. It
also in the rear end of my Model T Ford. which has a two speed
rear end. I have 78,000 miles on my Ford with no
problem with the rear end. I had to take up the rods bearings
several time in that many miles. I also use this
Hub Oil in my 67 Pontiac which has a 4 speed transmission.
I have it in the rear end and I have over 300,000 miles and
the rear end and remission still works well to this day.
You can get this at your local Napa Auto parts
store. Have fun with this one.
Happy Motoring.
Bob Hopkins Jr.
