Question on Electrolock
Evening all,
Is there a way to remove the lock without the proper key? I picked up a 29R sedan parts car and the engine is 100% intact. I do not know the status on the engine yet. I've got to loosen you the starter pedal, clutch
pull the plugs - ATF into the cylinders , change the oil, pull the valve covers, etc - ya know.
I'd like to leave the electro-lock in tact getting a new key made. I remember you can remove the lock with the correct key but with no key is there a way? I've got keys for my other 29Rbut they fail to turn the lock.
Thanks
Jack
Thanks
Jack
