Re: Removing Door Handles [1 Attachment]
#ygrps-yiv-1383415886 .ygrps-yiv-1383415886ygrp-photo-title {
TEXT-ALIGN:center;WIDTH:75px;HEIGHT:15px;CLEAR:both;FONT-SIZE:smaller;OVERFLOW:hidden;}
#ygrps-yiv-1383415886 DIV.ygrps-yiv-1383415886ygrp-photo {
BORDER-BOTTOM:black 1px solid;BORDER-LEFT:black 1px solid;BACKGROUND-COLOR:white;WIDTH:62px;BACKGROUND-REPEAT:no-repeat;BACKGROUND-POSITION:center 50%;HEIGHT:62px;BORDER-TOP:black 1px solid;BORDER-RIGHT:black 1px solid;}
#ygrps-yiv-1383415886 DIV.ygrps-yiv-1383415886photo-title A {
TEXT-DECORATION:none;}
#ygrps-yiv-1383415886 DIV.ygrps-yiv-1383415886photo-title A:active {
#ygrps-yiv-1383415886 DIV.ygrps-yiv-1383415886photo-title A:hover {
#ygrps-yiv-1383415886 DIV.ygrps-yiv-1383415886photo-title A:visited {
#ygrps-yiv-1383415886 DIV.ygrps-yiv-1383415886attach-table DIV.ygrps-yiv-1383415886attach-row {
CLEAR:both;}
#ygrps-yiv-1383415886 DIV.ygrps-yiv-1383415886attach-table DIV.ygrps-yiv-1383415886attach-row DIV {
FLOAT:left;}
#ygrps-yiv-1383415886 P {
PADDING-BOTTOM:3px;PADDING-LEFT:0px;PADDING-RIGHT:0px;CLEAR:both;OVERFLOW:hidden;PADDING-TOP:15px;}
#ygrps-yiv-1383415886 DIV.ygrps-yiv-1383415886ygrp-file {
WIDTH:30px;}
#ygrps-yiv-1383415886 DIV.ygrps-yiv-1383415886attach-table DIV.ygrps-yiv-1383415886attach-row DIV DIV A {
#ygrps-yiv-1383415886 DIV.ygrps-yiv-1383415886attach-table DIV.ygrps-yiv-1383415886attach-row DIV DIV SPAN {
FONT-WEIGHT:normal;}
#ygrps-yiv-1383415886 DIV.ygrps-yiv-1383415886ygrp-file-title {
FONT-WEIGHT:bold;}
The door handles are screwed on to the lock housing
by a threaded collar. You need a very thin 5/8"A.F. spanner, inserted
between the escutcheon and the handle and unscrew. Be careful, these
collars are pot metal. The seat adjusment does actually raise the seat
assembly as you screw it, as well as bringing it forward the angle of the seat
alters, and the rollers sit on the steel insert. You are adjusting
primarily for leg length rather than torso height.
----- Original Message -----
Peter
Ransom
Peter
Ransom
Sent: Friday, October 18, 2013 7:05
PM
PM
Subject: [HSS] Removing Door Handles [1
Attachment]
Attachment]
Here we go! I need to get at the internals of
the door locks on the '29 Landau. Removing the window winders is
straightforward, but the internal handles appear to made of pot metal and it
looks as though they've been pressed onto the shafts. I sense potential
for disaster. Is there a way of removing those
handles?
handles?
Front seat adjusment (bench
seat). The little rollers under the rear of the seat run on
flat pieces of steel which are only fractionally proud of floor level - see
the pic attached. For some reason these pieces of steel don't look
right. They're only roughly secured by some modern screws.
As they're flat the it's only the front of the seat that elevates - due
to the hinge arrangement - as the seat moves forward, but logically you want
the rear to elevate too because you're adjusting for a smaller person.
What's the proper arrangement?
Thanks... Peter
