Re: Seals - Which Way? [3 Attachments]
If you look at the seal lip you will see that in
one orientation it will keep grease/oil in. This orientation should be
facing inwards.
facing inwards.
Karl
----- Original Message -----
Sent: Thursday, August 21, 2014 8:27
PM
PM
Subject: [HSS] Seals - Which Way? [3
Attachments]
Attachments]
I'm getting close to reassembling the '29H rear
axle. The mangled CWP set is being replaced with 1928 parts, new carrier
and pinion bearings are going in and I have some new
seals.
seals.
The pics attached show the wheel bearing adjustment
nut seals - the type that was there when the nut came out and the new
seals. My question is: which way should the new seals be installed -
open side facing out, or the other way around?
Thanks
Peter
