1926 Super six
Hi All
My name is Frank. I have a 1926 Hudson Super Six 2 dr Coach. She has been in the Family since the 1950's.
It is an original car that has been running and has been to a number of AACA shows and has been certified HPOF. The problem is that water gets in the oil. I change the oil and run it from the trailer to the show field and back to the trailer.
I now have some time to address the issue. I have removed the head and have found a small area that may be one issue that may be solved with a new gasket. However I have found a crack by the drain plug in the block. This has always leaked a little as long as I can remember.
Ill try to attach pictures
Any suggestions?
