Condenser
Attachments :
I'm inching closer to a first attempt at a startup. I do not have the Electrolock Ignition so is this condenser wiring sufficient? The green wire goes to the negative side of the coil.
When ready, I will attach the 6V battery positive to the coil and the negative will ground to the engine. I'll probably use 12V on the starter.
Am I missing anything?
Ken in STL
Ken in STL
