Multi disk clutch springs
Attachments :
1. Has anyone had the small springs re-manufactured for the the 16-22? multi-disk clutches? These springs are .760 OD, .572 ID, .440 height, wire .032 thick, .092 wide, three coils (two "shims" - flat ground, one coil). Made from steel. Each clutch uses 32 springs per set.
2. Anyone else need new springs? I got a quote to have them manufactured and the set up along is $350. The amount doesn't really impact as that is a small percentage. So 50 or 2000, not much difference in price. I would also make them a little stiffer than originals.
