Re: 29 upper door jam weather strip [1 Attachment]
Attachments :
Evening Geoff,
Yes, there's about a 1/16" gap or a bit bigger between the trim piece with screws and the upper chassis frame where the roof bolts to. Looks like a rubber strip went across to meet the door when it closed.
Thanks
Jack
Jack
-----Original Message-----
From: 'GeoffClark' geoffclark@xtra.co.nz [HudsonSuperSix16-29] <HudsonSuperSix16-29@yahoogroups.com>
To: HudsonSuperSix16-29 <HudsonSuperSix16-29@yahoogroups.com>
Sent: Sun, Feb 28, 2016 4:09 pm
Subject: Re: [HSS] 29 upper door jam weather strip [1 Attachment]
[Attachment(s) from GeoffClark included below]
Are you talking about the strip that the top of the door trim fits against, which screws to the roof beam?
Geoff
----- Original Message -----
Sent: Monday, February 29, 2016 10:50 AM
Subject: [HSS] 29 upper door jam weather strip
Afternoon Guys,
I'm looking for a recommendation as to a weather strip that you guys use for the upper door jam. Looks to probably be flat on the side to fit under the jam and the other may be rounded fitting against the door.
Ideas???
Thanks
Jack
| This email has been sent from a virus-free computer protected by Avast. www.avast.com |
