sealing stepdown body
finally ready to start reassembing my 53 superwasp and am looking for ways to seal the vechile from dust and rain fenders trunk etc all ideas or products would be appreciated. this car was completely dismantled and all parts blasted. rusted parts repaired. body work will soon be complete and painted and then reassembled.
thanks steve
thanks steve
The attached pictures show what I did to my '48. These are pictures of the drivers side area. I took it down to the metal, sprayed Eastwood "Corroless", then sprayed rubberized undercoat. I've got plenty of "double-backed" foil insulation to attach, then carpet will go over that. That ought to be enough of a barrier to keep out rust, motor noise, and heat. The last picture is of me stripping down the body, after completing the entire inside of the car like I discribed. Just one man's idea, I'm sure more will follow.0
Now that's some serious work! But in the last photo, you look like the "Invisible Man" from the 1940(?) movies or maybe someone getting ready to stick-up the local Quicki-Mart. LOL0
I have use POR-15 in the past with good success. You can find a lot online about the product.
Matt0 -
bartibog1 wrote:finally ready to start reassembing my 53 superwasp and am looking for ways to seal the vechile from dust and rain fenders trunk etc all ideas or products would be appreciated. this car was completely dismantled and all parts blasted. rusted parts repaired. body work will soon be complete and painted and then reassembled.
thanks steve
Chassis saver works very well also about $75 for a gallon0 -
Steve,
The original Hudson body sealer appears to have been an asphaltic product, which was used in a number of areas. I've encountered it in the trunk, where the floor meets the inner fender, etc., and where the rocker panels are attached to the perimiter frame. They used a heavy bead of this material on my Hornet. 'Bout half an inch diameter on the rockers, and more in the trunk. Because mine had hardened completely on the rockers, I removed the old material and will use 1/2" x 3/16" Permagum strips (doubled) on the Rockers when they are reattached.
In the trunk, I used a product I got from Restoration Specialties which was made by Au-ve-Co to reseal the areas where I removed it. It is simply called body sealer 1001. I bought natural color, and covered it with 3-M undercoating which I used on the trunk floor and inner fender wells. Hudson also used a fiber/noodle like material (it looks something like a mouse would have in a nest) inside of the perimeter frame, at least in the rear. I have not changed it--- I'd use the Au-ve-co product with the rockers if I could figure how to apply it easily. I've used permagum strips on the door sills with good results too.
The Hudson Body Service Manual has a section on sealing. see p 87.
Walt0 -
Walt-LA wrote:Steve,
Walt
I hear that "rats nest" stuff really caused a lot of dirt and crud to build up and is usually a first rust out point on stepdowns.
The Auveco is good stuff - a trick to smooth the edges out is you can take an acid brush and a small amount of enamel reducer (spit works too...but takes a while to get enough material :rolleyes: ) and lightly brush over it.
You can paint over this stuff in about 1/2 an hour - but I ususally give it a couple of days or more depending on humidity and temp...I like it to have a good hard skin on it as it can also be lightly sanded to make a nice finished surface.
Another thing I do is that I do not apply body seal until the car (or repair area) is sanded w/400 and nearly ready to paint. Then I apply the sealer over the primer and smooth as suggested above. Then when cured - lightly sand w/400 to finish smoothing (if needed) , then spray sealer (always seal before paiting) and then topcoat as needed.
I would stay away from using it on the rockers and definitely not on the quarter panel seams...this stuff hardens up and would be a major PIA to try and remove the panels for any future repair work.
I'll make one more suggestion that they didn't include on the factory seal job (no good if you are going for a #1 resto...) anywhere there is an open drain hole I am going to used a "auto-levelling" sealer compound - so that when water is collected it actually makes it to the drain hole rather than sitting and rotting out another section eventually.
Someone will thank me down the road!
There are some newer seam sealers that have more of a "flow" characteristic to it and doesn't need to be smoothed.0 -
What was the composition of the Dolphinite product that Hudson and others used back in the day?0
The more I loooked at these pictures, the more I want to take my hudson down to this level of disassembly and do it right.0
hudsonkid wrote:The more I loooked at these pictures, the more I want to take my hudson down to this level of disassembly and do it right.
IMHO - If you can at all afford it and If you currently have a driver - drive it and find another one to tear down.
That way you can still enjoy one while working one - Kinda like having your cake and eating it too!
That is unless you can stand not driving your Hudson for 1-3 years while you tear it down and build it back up...0 -
I use in my shop, and highly recommend, 3M brushable seam sealer, which comes in a quart can, and can be purchased at your local auto body supply.0
