WTB 52 door hinge pins
scotts52
I need the front door hinge pins or complete hinges. Working on a 4 door Super 6. They weren't loose or anything. They just snapped. I bought the car and as I was loading it up, the upper door pin just snapped. Looks like they were a little rusty and locked up. I'm afraid both front doors need attention. Back doors seem ok.
The problem with the hinge pins that Hudson used was that they were heat treated very highly . That made them very durable but somewhat brittle. The fun part is removing the remains of a flush snapped off hinge pin on a hinge plate. FUN with a capitol F if you know what I mean. Best substitute is to get a grade 8 bolt and turn it down on a lathe. works great.0
So Lance are you saying a good replacement pin can be made from a Grade 8 bolt, somewhat oversize? Cut the hex head off and turn down the diameter as needed and cut to length cutting the threads off. If no other offers I would gladly give it a try. I would need exact finished diameter and length. Retired machinist Gert, HETgtkristi@comcast.net0
Gert, Check your email.0
Lance very kindly provided me with the dimensions from an original pin. Anyone know if these were a tight press fit into the hinges ? Of course the hole in the hinges could have worn oversize. Anyway I am ready to proceed - Scott email me if you want . I know this is difficult both to remove them and replace especially if the hinges remain on the door post and door. I think you need a jack holding the door up into position from the bottom of the door. Cant let it twist. Good luck Gert0
- 81 Hudson 8
