Transmission and Rear Axle Oils - 1934 Hudson
I'm about to do a complete change of the oils in the transmission and rear axle of my '34 H8.
I know that I have to use yellow metal friendly oils but I don't know if I need to use classic EP (Extreme Pressure) or classic non-EP - which is it ?
I don't use the car when the temperature is less than 40F, so can I use summer spec SAE oils all year round ?
Advice would be greatly appreciated, please !
David.
EP additives with certain sulphurs are very bad for yellow metals. GL-4 oils are yellow metal safe
I do not change transmission or differential oils with seasonal temp changes.
regards, Tom
Thank you, Tom.
You can get yellow metal safe EP oil here in the UK so I just wanted to check whether I needed it, but it seems I don't.
Is GL-1 oil OK as well ?
GL-1 is compatible with gearboxes that contain yellow metals
regards, Tom
Thank you again, Tom.
I'm guessing I'll be safe using this one for the transmission and the axle ?
80w90 Gear Oil Mineral GL-4 Yellow Metal Safe – Westway Oils
Best wishes,
David.
Yes
regards, Tom
Thanks again, Tom.
I've ordered a 5L can.
D.
- 104 Hudson 1916 - 1929
- 19 Upcoming Events
- 91 Essex Super 6
- 993 Street Rods
- 172 The Flathead Forum
- 599 Vehicles
