1929 super six interior
all interior trim in this metal car is a mystery to me. trying to renew some upholstery and cant see how to remove trim around doors and rear wheel arches etc. help please. someone must have redone one of these interiors, or they just made with no way to get them apart again? thanks
No problem, the trim strips are screwed to the door posts, and the material is glued to the strips. The weathersealing is clamped into a groove in the door strip. Just prise it apart.
thank you. is the rear trim at the bottom of the wheel arch inside rear door attached in similar fashion? Once again thank you very much for the help.
Yes. the windlacing is the tricky bit, but it is all pretty straight-forward.
if i strip off the fabric from the wheel arch area will i find screws there also? thank you again
Yes, the trim strips are screwed in place.
- 81 Hudson 8
