1933 Jack and lug wrench storage
Where did Hudson store the Jack and lug wrench in the ‘33 convertible and roadsters,
Not an issue now as I don’t have either. Haha.
regards, Tom
I see the internet says either in the rumble seat or under the drivers seat for 2 door convertible coupes with rumble seat.
anyone on here n who can confirm and perhaps post a picture of theirs so I know what to look for in jacks and lug wrench?
thank you.
regards, Tom
Well it wouldn't be under the front seat, as it is not movable,and is tight against the floor... I guess they were kept in a burlap bag in the rumble seat floor area, no provisions to fasten in place. The owners manual leaves much to be desired, no instructions about the jack, also no instructions on raising, securing or lowering the top. I assume because Briggs body co. only converted a few hundred coupes, so it wasn't deemed essential. And good luck changing or servicing the battery, for obvious reasons!
Mine has a seat adjuster ( more show than go, as it only moves a couple of inches) the seat bottom sets in like my ‘35. It does lift out. As I am well down the list of owners, I am not sure if it is “borrowed” from another car.
regards, Tom
As you can see on this original '33 convertible seat, there is no room under the cushion or under the seat!
Thank you. I knew the floor was flat, I did not know if there was space between the floor and the seat springs.
I do see the seat position adjuster. Seat moves all of about 2”.
Is that an original jack handle in your pic?
thank you again.
regards, Tom
I believe it is
A complete '33 tool kit assembled by Kerry Haggard
Wow, That is great. Good work Kerry.
thank you for posting 5433HET
tegards, Tom
Does the seat back hinge forward? My '33 Terraplane rear seat back did this, with space in behind it for tools and the jack.
I am away from home for a few weeks. I will check when I get back. The car is new to me. This is a convertible coupe with rumble seat. I did not think it did. The rumble seat footwell is right there, but I will look.
regards, Tom
The 32-33 Convertible seat was not hinged, so stash the tools on the Rumble seat floor
Could you post a photo of the jack please. I am trying to locate one for a fellow Hudson enthusiast.
Many thanks. Regards
Phil
Phil, see the picture above in this thread posted by 5433HET, credited to Kerry Haggard. Kerry has a Jack in the lower right hand corner of the display.
regards, Tom
The jack in the photo is blurred especially when blown up. I am looking for a clearer photo especially of the top screw mechanism.
- 612 Vehicles
