Stepdown Frame Repair
As I recall, it's 19ga. (.0419), which is no longer available. But, when shopping, you can find small 18 ga. (.0478) or thick 20 ga. (.0359) metal if you take your calipers when going through a stack.
Senior moment. This might be the body panel thickness. I will double check my frame in the next couple of days.
1 -
So, it's hard to tell with the rocker installed, but best I got was .0750, which equates to 14ga. At least on the perimeter frame.
