Pitman arm removal
Trying to remove the pitman arm on a 36 Hudson and I give up. I’ve tried a regular puller and heavy duty puller and neither one will fit. Between the three studs holding the steering gear to the frame, the arm itself, and a weird bump on the frame there’s no way I can get both arms of the puller on. I even removed one of the nuts from the gear studs to try and get a little more room but it didn’t help. Suggestions?
frustrated and defeated
jeremiah
All you have to do is go to the auto parts store and buy a pitman arm puller they are really cheap and they work great they are made just for taking off pitman arms that is how I got the pitman arm off my 36 like you I also tried everything to get mine off then my brother told me what to buy with the tool it took me less than ten minutes to get it off Tom.
- 81 Hudson 8
