gasoline...
bull_islander
What do you guys run in your Hudson engines? Straight unleaded? 87, 89, 93 octane? Do you put any additives in it?
I sold my '53 Hornet a few years back and am looking at getting a '52 Commodore 8 now and am curious about the gas. Recently (at least around here), the ethanol content was raised to 10% and wanted to know if anybody was having any issues with that.
Thanks.
Thanks.
I use 87 octane regular. No additives. The biggest problem with ethanol is the deleterious effect it has on rubber parts in the fuel system. Therefore, using old fuel pumps, old fuel pump rebuild kits or pre-fuel injection rubber gas hoses is out. The upside is that with ethanol in gas, people in northern climates no longer require the use HEET. Good luck with your 52.0
Heet????????0
HEET: A gasline anti-freeze additive.
Kiwi?????????0 -
Dave53-7C wrote:HEET: A gasline anti-freeze additive.
Kiwi?????????
When I fill up using ethanol and don't drive my car for awhile, the carbs lock up. The throttle shaft freezes up. Maybe its just coincidence. This has happened numerous times. I now do my best to avoid ethanol like the plague. I have spoken to others that this has happened to also. I will go back and start adding a little bit of Marvel Mystery oil to my fuel again.0 -
7XPacemaker wrote:When I fill up using ethanol and don't drive my car for awhile, the carbs lock up. The throttle shaft freezes up. Maybe its just coincidence. This has happened numerous times. I now do my best to avoid ethanol like the plague. I have spoken to others that this has happened to also. I will go back and start adding a little bit of Marvel Mystery oil to my fuel again.
Why would this happen? What is in the carbs that would cause this to happen? Or is it the fuel aging and getting stale thus gumming up the works?
I understand the rubber issue (had one my Dodge Dakota PU in 91, manual stated do NOT use Ethanol). And the one short piece of flex fuel hose I do have is modern materials rated for all fuels.0 -
I have been using the low 86(?) octane in my 49 Super Six. The timing is a bit retarded from where I would like it, but It doesn't ping. Mid grade would give better perfromance from what I feel in the seat of my pants. We live in Fl. Have no idea whats in the gas. My rubber fuel line from the fuel pump to carb just gave up after 9 years. I may go back to a steel line If I find one.
Dave w. Fl0 -
Dave Kostansek sells the rubber fuel lines made from ethanol compatible material. His fuel pumps (as well as most other rebuilders these days) are also compatible.0
I think that the gas gets stale and gums up. This is just a guess.0
maybe we send him a few bottles of heet
SuperDave wrote:I have been using the low 86(?) octane in my 49 Super Six. The timing is a bit retarded from where I would like it, but It doesn't ping. Mid grade would give better perfromance from what I feel in the seat of my pants. We live in Fl. Have no idea whats in the gas. My rubber fuel line from the fuel pump to carb just gave up after 9 years. I may go back to a steel line If I find one.
Dave w. Fl
If they do put Ethenol in your fuel the station is required to clearly post the fact on the pump and the ratio. You should be able to take a look next time at the station and check for yourself.
I only know of 2 types of mixes 10% and 85% - but there aren't any stations here in Taxington that sell the E85 blend. And we're almost running the 10% mix hear year round - no way to avoid it...0 -
I always run regular 87 octane Haven't had any problems. If I remember correctly I read somewhere that when the stepdown came out in '48 octane the general rating was more like 80 and Hudson was saying something to the effect that with their higher compression head they could make better use of higher octane gas.0
I think the statement was from A.E. Barit to a reporter stating that more horsepower could be derived from Hudson's existing engines (by design) when higher octane fuels became available.0
I heard (no documented evidence) that the ethanol holds moisture and, when it sits, it can cause tanks to rust and carbs to stick. It's not a problem when the car is used daily.0
yep that was the statement Dave!0
Thank you for the explanation of Heet. being a temperate climate, we don't generally have the need for such stuff. In fact the oopposite applies, the unleaded gas we get here is of a very high volatility, and we have the opposite problem of vapour-lock when not even very hot. And Ethanol blending is in the offing here, so we can look forward to having to replace our fuel pumps and flexible lines. On the Octane thing, my Jet and Hornet detonate badly if I work them hard running 91 Octane, so for the slight extra cost I run 96 Octane. It never used to be a problem on 91 grade leaded gas, so I guess it's the unleaded rubbish that has changed in specification somehow. Another thing I notice with unleaded as compared to the old leaded gas we once used, is decidedely rough running when cold.
Geoff.0 -
More Fodder!
Unless you've done higher-compression modifications, and I mean pretty serious ones, buy the lowest octane fuel available.
Ethanol is in most fuels in the US now, and a 10% concentration shouldn't hurt anything. Yes, maybe over the course of several years, rubber parts will soften, but you're not going to immediately kill anything. E85 is a different animal; with 85% ethanol you're likely to barbecue something. That's why modern flex-fuel vehicles use neoprene and such in the plumbing. As far as I know all of the new fuel hose manufactured by Gates, Goodyear, etc. is compatible with today's roughly 10% blends.
The statement about gas in bygone days being lower in octane is correct. With prehistoric cars like my '29, gas was closer to 60 octane. When Phillips 66 came out, the reason for the "66" was 66 octane! I believe the statement is correct that by post- WWII, in '48, it was about 80 octane.
I read a post above about running the timing slightly retarded when running 87 octane. This may be a bad idea if the timing setting supplied by the manufacturer was for, say, 80 octane. Reason: The higher the octane, the slower it burns. This necessitates more advance for higher octane numbers. You won't get any ping out of retarding the timing; you'll get it out of advancing it. On the '29, I time 6 degrees ahead of the factory specification. Factory says 3 flywheel teeth BTDC, and I time at 4. Seem to have no problems there. Then again, there's a big difference between 60, as it was designed, and 87, what I'm using. So, using 87 in an engine designed for 80 might not require a change at all. I'd use the foolproof method of lugging the car in top gear and advancing till a slight ping, then retarding slightly. I recommend setting your INITIAL timing with a vacuum gauge by advacing to the highest vacuum reading (vacuum advance plugged if you have it) then retarding about 1 pound. That will give you a place to start.
Geoff, something occured to me with your statement-- there are at least two methods used in different parts of the world for measuring octane rating-- and forgive me if you know this already. One is the Research Octane Number (RON) and the other is the Motor Octane Number (MON). In European countries, and all of Australia, and probably NZ, the posted octane rating is the RON. In the United States, the average of the RON and MON is used, known as the R+M/2 method. This method is sometimes called AKI or Anti-Knock Index, or PON, Pump Octane Number. What does all this mean? Gas in the US will be about 4 to 5 points lower advertised than the same gas elsewhere. 87 in the US is more like 92 or so in other parts of the world. I remember reading in the owner's manual for my 86 Porsche 944 to use 87 octane in the U.S., or 91 octane elsewhere.
I do not use lead additives in any Hudson engine as I've never heard of or seen one with a valve recession problem, and most Hudsons were built before the introduction of Leaded gas anyway. I do however use Marvel Mystery Oil in the gas tank of my '29, 4 ounces per 10 gallons, for vacuum tank, carburetor, and upper valve train lubrication.
Hope this helps.0 -
bull islander wrote:What do you guys run in your Hudson engines? Straight unleaded? 87, 89, 93 octane? Do you put any additives in it?
Thanks.
I own a 52 Commodore 8 sedan that I am in the process of restoring. Are you looking for a 52 Commodore 8 to buy or have you found one that you are interested in buying? I went through the Club roster once and if I remember right, I counted less than ten 1952 Commodore 8's and I believe there were only around 3100 made.0 -
I'm not sure of the scale they use here for unleaded gas, whether it's MON or RON. All I do know is that it is inferior to the old leaded gas, both for cold running and detonating, so I guess they changed the system. The 96 octane has a very short life, unless the fuel tank is filled right up. If left for any length of time with less than a full tank, all the aromatics evaporate out, and the rest goes rotten, causing hard starting, rough running, and a really bad smell! The 91 Octane is not so bad, it will store for longer without going off. All the modern Jap cars are designed to run on this, but the Jet and Hornet don't like it much. The Essex runs fine on it. I have also diluted it 30% with aviation kerosene, and it goes fine on that as well, except it smells like a 747 taking off. I have to set the Jet ignitiontiming just 2 point b.t.d.c. to stop detonating when accelerating at high speed. The vacuum advance is working properly. and it never used to do this. Guess I will just have to live with it. Pity though, because I think performance and economy must both suffer.
Geoff.0 -
SRCraftsman2 wrote:Are you looking for a 52 Commodore 8 to buy or have you found one that you are interested in buying?
Looking to buy one from a club member. So it won't be a new one, it should be one of the one's you counted!0 -
jamcoats,
Thanks for the explanation above. That's great information to have!
hudsonly,
Doug0 -
Doug,
Not a problem, I have a hard time keeping my mouth shut anyway. It's an occupational hazard in my business. Click the rep power button!
Happy Holidays0
- 183 The Flathead Forum
- 611 Vehicles
