How to prime/bleed completely dry hydro system?
I already have windows/regulators in and new hoses/lines installed. Project for weekend is to install new top cylinders/hoses and get top and windows working.
Yes, I have a body manual. and believe it or not, I have read the top section. That being said, I am seeking advice from someone who has already done this as the book really does not address the sysem when it is completely void of all fluid.
SOOOOOO, can someone who has had a stepdown convt please let me know the best way to fill and prime and bleed the system when it is completely dry????? I am sure there is some trick or advice that I can use.
Thanks
Thanks
Dennis
ask the man who has done it LOL good way to go what i did when building 'BABY'
WAS TAKE BOTH LINES AT THE TOP CYL'SLCRACKED LOOSE AND JUST HAVE A FRIEND BUMP THE TOP BUTTON THEN WHEN I GOT FULID AT THE CYL'S I TIGHTENDED UP THE LINES THEN WENT THE OTHER WAY AND WHEN I GOT FULID THERE I TIGHTENED THEM UP NOW THE DOR AND REAR WIDOWS IS ANOTHER THING THEY GO DOWN WITH SPRING PREASURE SO ALL YOU HAVE TO DO IS BLEED THE AIR OUT WHAEN YOU GET FULID TIGHTEN THE LINES UP I HOPE THIS HELPS GOOD LUCK
HUDSONLY
PAUL0
