fan separation
just how do you pull the fan from the blower motor in a stepdown without crushing anything? im guessing that being firm friends for 56 years has ensured the fan is rusted onto the motor shaft. failing that what 12v fans and motors fit into a stepdown heater case.
The best way is to get penetrating oil { WD 40 or Liquid Wrench} onto that odd shaped nut that holds the fan cage onto the motor shaft. Let it soak overnight and then get a pair of alligator snout Vise Grips and turn the nut in the normal fashion. They will seperate but be careful not to bent the fins of the fan cage as it will impede its effect. Notice too, that the fan cage has weights attached so it is properly ballenced.0
i got the grub screw out no worries. thats no problem. just that its so bloody stuck! maybe ill take it to the factory and play with bigger instruments of destruction0
