Stepdown frame repair
From memory the chassis rails are 1mm/40thou, floors are half of that. But I'd measure it to make sure.0
16 gauge is what I am using for sheet metal repairs and the outer perimeter frame.
I believe the inner frame rails are 14 gauge - but these rarely need repairs other than spring mounts....0 -
Thanks guys for your help!
Tom0 -
Tom Drew wrote:For those who have done welding repairs to the frame rails & floors of the stepdowns, what guage steel are you using for these areas? Thanks for any help provided.
Tom Drew
Check out my website.... the following link goes to a sheet on frame repair.
Note that recenly one of the California HETers bought a frame rail from Vic Z to replace the spring mount area of his frame. Cut and weld in which created a factory quality repair.
Good Luck
http://members.aol.com/rcsacimt/Re0 -
Thanks, Ken. Really informative and much appreciated.
Tom0 -
You do know that front floor patch panels are available, right?0
I believe the inner frame rails are 14 gauge - but these rarely need repairs other than spring mounts....[/QUOTE]
I can vouch for that !!!
terry0 -
Gus Souza told me you can take out the rotted rear from by removing the seam sealer and drilling out the pinch welds the factory made then weld a good frame section back into it might want to call him if you get stuck.0
Thanks Jon, I do know about the floor pans available from Ken Amman. Luckily my rust issues are relatively minor but do require some small areas of metal replacement. I appreciate all of the responses - all that's left to do now is fire up the welder!0
Tom Drew wrote:Thanks Jon, I do know about the floor pans available from Ken Amman. Luckily my rust issues are relatively minor but do require some small areas of metal replacement. I appreciate all of the responses - all that's left to do now is fire up the welder!
I hate you :mad: - nah - just kidding!
I wish mine hadn't had the rust issues - of course I bought mine site-unseen on ebay...the #1 thing not to do with a stepdown!
Of course everytime I see pictures of the prototype Jet convertible I feel really lucky0 -
No offense taken, Dan. I'll just try to live up to the standards you've set with the sheetmetal work on your '49.
Tom0
- 106 Hudson 1916 - 1929
- 19 Upcoming Events
- 91 Essex Super 6
- 561 "How To" - Skills, mechanical and other wise
- 994 Street Rods
- 174 The Flathead Forum
- 602 Vehicles
