Need 46 PU Spring shackles plus mounting
I finally got the spring shackles removed from my 46 Hudson PU. It looks like I not only need new shackles, but also the screw in caps AND the sleeves that weld into the frame. :mad: The very end of the frame seems to have been subject to more corrosion than the rest. The side of the sleeve that is welded into the frame rusted out and into the screw in cap a little. It appears that the lower (spring) end of the shackle is not very worn, but of course I need the whole shackle. Any idea where I can get all three pieces for both sides?
