Electrical Problem on Jet
I have tried to make sure that I have a good ground. Could the problem be in the drivers side head light ( like a bad ground) or could it be the other one even though it seems to work ok. Also the parking lights will not work unless the the metal part on the bulb itself is grounded. ( it was like that way before I took it apart) I am still using the six volt system.
Sorry, I forgot to ask if anybody has got any ideas, and thanks,
Barry Smedley0 -
It does sound like the light assemblies aren't grounded. Happens when you paint everything fresh. Use some temporary jumper wires to make sure all four light sockets have a good connection to ground, and see if that makes everything right again.0
Park is right, you have a gropund connection problem. The ground wire from the headlight and park lamp should be connected to the mounting screw for the terminal blocks either side of the radiator mounting. Double check that you have the correct wires connected for the filaments and ground on the sealed beam connector back to the terminal block. If neceassary, connect a ground wire to the park lamp housing and run it back to the chassis as well. (drill and tap a hole in the housing to connect the ground wire). You get strange things happen when there is no earth - e.g. both headlamp filaments will glow dimly. Good luck,
Geoff.0 -
Thanks, guys, That is what it was I had the parking light wire and one of the head light wires crossed, she works fine now! I guess when I took the inner fenders out and the radiator frame out to paint I must of crossed them when I put it back together. Or just a brain f*#!.
Thanks, Barry Smedley0
- 184 The Flathead Forum
- 611 Vehicles
