Need 50 Comm. Regulator Help
thekid1950
My 50 Comm 6 is not charging. I ran it with the battery neg. terminal grounded, which caused the problem. I flipped that battery around to pos ground. I polarized the gen but no help. I wanted to swap out another reg that came from a 50 Pacemaker to see if that would help.
The 2 regs are different.
The reg that's on my Comm has the A, F & B terminals...but it also has a lone single terminal at the top directly on the opposite side of the B. This lone unmarked terminal confuses me. A wire is attached to it and joins the wiring that goes thru the firewall.
The reg from the Pacemaker doesn't have this extra lone terminal on the top.
I checked and the lone terminal is not hot. Switch the key on..still not hot.
If I swap the reg. I have nothing to attach this wire to.
Can anyone shead some light on this?
If I convert to an alternator with internal reg....what would I connect this lone wire to?
Thanks
thekid
Thanks
thekid
This thread will explain it all for you.
http://www.classiccar.com/forums/showthread.php?t=8866&highlight=Regulator0 -
Thank you....that thread is the answer!!!
I'm a happy camper now!0
