What Compression Is My Engine?
With Cast Iron head its 6.7:1 and with Aluminum head its 7.2:1 when you do a compression test you should get 100 Lbs minimum per cylinder.0
unless you got a 308 with a 262 head on it, then it will be a bit higher...
prolly (just a guess...) 7.5:1 anyone really know?0
