vacuum tubes/stepdown radio
Hudson Grandpa
You may have to find this info upside down, like I did...
On a 54 Hornet Radio there are three vacuum tubes. At least on my
radio that doesn't work. The left tube is a 6AQ5. The right tube is
a 6X4. Does anyone know the type of tube that is in the center.
If you can pull that center tube out, don't wipe it with a rag or the like. Rather, breathing on it will reveal otherwise illegible markings.0
I assume you have a Sylvania.I have a '53 I believe they are the same.The tube in the center is 6AQ5.They are audio output tubes. The other one,6x4 is a rectifier.0
Thank you, I figured it had to be a copy of one of the two that are in there.
The middle one is missing. I'll bet when I replace the tubes, and see if the fuse is ok, I'll get some activity. Everything looks real good..0
