R-10 Overdrive on Ebay
For those who do not already know ... the overdrive used in the Stepdown is a R-10 Borg-Warner unit. This unit along with the standard Borg transmission T-86 were used in many other cars. the internals and externals for most of these applications are the same as Hudson. Albeit you need to carefully compare to assure that the parts are truly bolt up or interchangeable. All this aside ... the BW overdrive on eBay is a perfect example of a part that was in a jeep that is the same as the Overdrive used with a Hudson T-86 3 spd trans.
Check it out....
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&rd=1&item=7965274104&category=46104&sspagename=WDVW
Enjoy
Ken
Check it out....
Enjoy
It gets better HETers.... a NOS T-86 with R-10 OD on eBay ...not sure but may have to change the input shaft... and will definately have to change the rear yoke... but you should be able to replace with parts from Hudson examples.
Check it out....http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&rd=1&item=7965222407&category=33733&sspagename=WDVW
Ken 0
