Need Parts
Hudson Grandpa
Hoping to find a transmission dust cover for a 54 Hornet cpe Automatic.
Also a 6 volt temp sending unit to fit a 308. Don't care what it looks like,
just as long as it works....
SPECIFY BORG WARNER AUTO OR HYDRAMATIC, DIFFERNT COVERS, HAVE NEW TEM SENDORS AT 15.00 EA bill albright0
Bill:
Sorry I cannot specify one of the two. Someone mentioned sometime ago that it was Borg Warner, but you couldn't prove it by me. However here is what reads in the shift lever. P N D L R. If you can derive anything from that
then please post it...
Sending you $15.00 for temp sending unit...0 -
That's the Borg-Warner trans. Hydro does NOT have a park position, That's what reverse is for!0
Grandpa where are you located?
Bob0 -
Add 5.00 For Postage With The 15. Thanks, Bill Albright0
Dave the temp sending unit does not care what voltage... it is a resistor that gets less resistant with heat. Try NAPA ECHLIN TS-6464, 1959 AMC 250 V8 1/4" pipe thread sender,
Note the trouble shooting information here too:http://www.classiccar.com/forums/archive/index.php/t-7242.html0 -
Borg Warner does NOT have a "P" for Park
I suspect it does not have a "P" on your select indicator; don't believe the Hydra-matic had a "P" either as every one I've seen "parked" was positioned in "R" for reverse, typical for the Hydra-matic's
So your description is VERY confusing.0 -
My 1955 Motor's Auto Repair Manual in the section for the Borg-Warner Automatic Drive shows a Parking Brake (as its called) in the sectional view, in the remove/install section and in the adjustment section it talks about moving the shift level toward Park position.0
54 HSWH wrote:
P N D L R is the correct indicator for the B-W automatic, and yes the park pin engages in with the selector in R.Borg Warner does NOT have a "P" for Park
I have attached scans of the Hudson Manuals showing the THREE different sector plastics which support the three different automatic transmissions. The pictures are posted in the following order...
- Borg Warner, 1954
- Single range Hydra
- Dual Range Hydra
The manual provides specifics on how to park the car and thier recommendations for use of the transmission selector.
During the restoration of a 1954 Hornet Sedan, I removed the BW automatic and installed a rebuilt Hydra from a 53 Hornet. The sector plastic from the 53 was used to replace the 54 piece. The installation viewed as factory... for all intents and purposes... it was ... just done by me.
Cheers0 - Borg Warner, 1954
Ken:
The first pic of the single range hydramatic is what my shift lever looks like.
Thanx for temp unit info...0 -
th first pic is of the Borg Warner aut not hydro, you have the Borg wasrner, that is why the hydro dust cover will not work, bil albright0
- 184 The Flathead Forum
- 611 Vehicles
