A/C Brackets and Alternators
ski4life65
Has anyone purchased a reproduction A/C bracket from Joe Stinnett in Florida, and if so do you have pictures of it installed? Also, which alternator is the easiest to install without too much modification to the original generator bracket? It has been pushing 100 degrees every day in Denver, and I need to get A/C in the Hornet if I want to drive it this summer.
Thanks
Don
Thanks
Don
Don,
I make a bracket by welding an ear onto the original bracket then use the GM Alternators from 70 - 80's with internal regulator. Belt groove can be aligned with straight edge or length of angle iron.0
