Reinstall of Oil Pan
I am finally ready to reinstall the oil pan and put things back to gether this weekend.
I have a new cork pan gasket and the rubber o-ring for thepick up line.
Should I use Indian Gasket goo on the cork, some other more "cork friendly" product or nothing?
Thanks in advance. This is one thing I forgot to ask when I took it off to clean it out.
Use your choice of "gasket goo" on the oil pan only. If you ever have to remove the pan again it'll make it a lot easier. My personal favorite is 3M trim & weatherstrip adhesive.0
Steve E. wrote:Use your choice of "gasket goo" on the oil pan only. If you ever have to remove the pan again it'll make it a lot easier. My personal favorite is 3M trim & weatherstrip adhesive.
Thank you.0
