Batt. charger start
You got it right Pos to Pos Neg to Neg. hook up the battery end first and then use the body/frame connection to complete the circuit and remove them in the reverse order. Body/frame removed first, then the battery. The idea is to not cause any sparks at the battery. The batteries can explode if a spark sets off the hydrogen gas in and around the battery. Been there...done that!
It also helps to shut the charger off befpre connecting and disconnecting.
Good Luck.0
