Clutch throwout seals found
barrysweet52
A clever Hudson man in Melbourne Austalia has found some replacement seals. They are approx $2 each. A General Motors inner seal off a front wheel hub (GM 9937294) fits on the yoke. These seals were used between 1979 ish to 1993.
An oil seal (TC 12462) available at most bearing shops is fitted to the inside of the leading edge of the yoke. A few thou may need to be machined out to fit this seal. Hope this is of interest . Regards, Barry. HETsweetman@virginbroadband.com.au Drop the HET
