Need replacement part #'s for stepdown u-joints and center drive shaft carrier bearin
Here are the part numbers for the bearings.
'48-'52 All Exc Pacemaker and Wasp use #88506
'50-'52 Pacemaker and Wasp use #88107
'53-'54 All Exc Jet use #88107
I am not totally sure about the above infomation. So here are the dimensions of the bearings. You can measure yours and pick the right one.
#88506
ID 1.1811 inchs
OD 2.4409
Width 0.9449 inchs
#88107
ID 1.3780 inchs
OD 2.8346
Width 0.9843 inchs
For the u-joints try NAPA 2100153 or Precision 369.0 -
On Page 46 Of Lou Backhus Swaps Manual It Says Same As 55 To 70 Chevrolet0
I just used a few precision 369, U-joints, should be available from NAPA for about $12 each. they work well. Send your driveshafts to hudsondad, and he'll press them in for you..... (oh wait... I guess that was just mine....) Oh well, you get the idea! best! Hudsonkid0
Neils Came By The Twin H Ranch This Morning And Picked Up Everything He Needs To Get His Coupe Back On The Road, Bill Albright0
These are standard metric size bearings, any bearing shop should have them.
The #88506 is 30 x 62 x 24mm
The #88107 is 35 x 72 x 25mm0
