308 Rear Seal
If it don't leak, don't fix it! You either have to remove the crankshaft, or the transmission , clutch, and flywheel, to replace this properly. there are other methods of trying to fix a leak here, such as packing behind the bottom section, and punching a small section up against the joint in the upper half, but they are difficult, and may not work.
Geoff.0 -
Or Replaceing The Rear Main Seal With A New Neophreme Seal I Have Them And Have Sold Many My 50 Pacemaker Cv Has One In It You Will Not Have To Remove Any Thing But The Pan And The Rear Main And All Of The Old Rear Main Seal But As Geoff Said It It An't Broke !!!!0
Paul, could you show a picture of the seal that you use ?
Thanks Rudy0 -
I scanned one which I have. If someone will post the scan, I'll gladly email it to them in JPG format. They were used on 318 Chrysler engines. Have to cut the "wings" or arms off... Very glad to hear they can be installed without having to drop the transmission. Walt-LA
HETKasaitrading@yahoo.com drop the HET.0 -
Hi Rudy I put a seal in my 308 Hornet engine from a 318 Dodge engine
1957-89 fits like a glove. It can't fit any better. Fel Pro BS 40245 .
or BAC/Nalional 5414 . Rudy what is the price of your seal to seal the dist.
in the 308 block. and a news flash our 54 Hornet Hollywood as of yesterday
is finished painting. Have a great Hudson day.Everybody.
Hudsonly Duncan0 -
Here is a thread on this topic including a picture.
http://www.classiccar.com/forums/showthread.php?t=9209&highlight=dodge0 -
Duncan, out of the seals at this time,but hope to have some in about a month.
Thanks Rudy0 -
Thanks to you all for the advice!
Jon C0
