Optima battery w/ battery box FOR SALE
$75 OBO for:
1) a good, used OPTIMA BATTERY (6v + 850 cranking amps), PLUS
2) the 6v BATTERY BOX with removable cover whick looks like the original 6v battery.
I just tested the battery and it's in the good operating range, GUARANTEED!
I will ship to you (25.5 #'s - my ZIP, 38138).
Just send me a private message.
THANKS
John
THANKS
John
AD IS BEING REVISED HEREWITH:
$75 OBO for:
1) a good, used OPTIMA BATTERY (6v + 850 cranking amps).
Advantages of the OPTIMA Battery:
* Delivers higher peak amps faster than conventional batteries
* Provides up to twice the life of conventional batteries
* More consistent voltage across the discharge curve
* Superior cold and hot weather performance vs. conventional batteries
* Spill-proof, even if the case is physically ruptured
Will not off-gas in normal operation, eliminating corrosion
Over 14 times more shock and vibration resistant than conventional batteries
Provides more power from a smaller package
True zero maintenance
Holds charge better during periods of nonuse
Operates in any position without spilling
Offers proven durability & performance
* Charged and ready to use
2) the 6v BATTERY BOX with removable cover looks EXACTLY like the original 6v battery, because that's what it is (the top was removed and the interior removed to accomodate the Optima battery very comfortably). Looking at it, NO ONE suspects an Optima battery is located inside! Looks original.
I will ship to you via UPS (27 #'s - from my ZIP, 38138).
Just send me a private message, or leave info on how to contact you.
THANKS
John0 -
$75 OBO for:
THANKS
John0 -
back to the top0
Dennis in NY; here is a response to your private message:
Your box is full; my reason for posting here.
It is an original, 6v battery; starting with the original battery the top was removed and all the insides were removed to make room for the Optima battery which just sits down inside the original battery box (top off), then the top is positioned back onto the battery box with the posts sticking thru in the correct location. Then one places the red and green post treatment felts in position and it looks exactly like an original battery, because that's what it is (but with Optima inside). Don't have a photo available to send. My word is my guarantee-no misrepresentation at all!!!!!!!!!!!!!!!!
John G Williams
7584 Foster Ridge Rd
Germantown, Tn 33180
- 117 Hudson 1916 - 1929
- 98 Essex Super 6
