water pump lubricant
Unknown
edited November -1 in HUDSON
What lubricant should be used in Hudson water pumps with grease zerts (ie 40-47)? The manual calls for an aluminum soap lubricant. What's that??
  • harry54
    harry54 Senior Contributor
    40-47 Hudson water pumps have zerks ?..... stepdown's don't....
  • Grease is like oil, a lot has changed since 1947, all for the better. I simply use a good quality multipurpose grease for about everything except wheel bearings,and where electrical grease is called for, whether it's a newer peice of eguipement or an old one
  • Huddy42
    Huddy42 Senior Contributor
    Try grease they use for marine uses.Available from any marine outlet.
  • mdwhit
    mdwhit Expert Adviser
    I've been using marine grease (blue) in my 1953 Nash for years. I think it works well. I have had a couple of water pumps go out (leak), but I do not think it was because of the marine grease.
  • mdwhit
    Forgot to mention that you can purchase the grease at just about any auto parts store.
    Thanks to all who replied. I have done a little more checking and found that aluminum soaps are made of napthenic and palmitic acids which when mixed with gasoline make "napalm"! I also looked on a can of water pump lube and found that the ingredients contain "napthenic oil mixture" . In addition there are companies I have never heard of (like Shanghi Naco Lubrication Co.) that make Aluminum Soap Grease. A friend has some left over from a 39 Hudson he had and has volunteered to bring it to the next meeting. I think I'll take him up on it.
    Thanks
    Steve
