Hypoid gear oil
The repair manuel says to use 90 SAE hypoid oil in the rear end and transmission. I used to be able to find it since a lot of marine transmissions called for it. The last few times I went to get it, all the parts stores had was 80W 90 gear oil. Is that the same thing or should I try harder?
Jason
Jason
JasonNC wrote:The repair manuel says to use 90 SAE hypoid oil in the rear end and transmission. I used to be able to find it since a lot of marine transmissions called for it. The last few times I went to get it, all the parts stores had was 80W 90 gear oil. Is that the same thing or should I try harder?
Jason
http://www.restorationstuff.com/Products/products.html
This place sells all kinds of oils and other neat stuff. Good Luck, Ron0 -
What is the car you are wish to change the gear oil in?0
HI JASON, old recomendations versus modern lubes sometimes creates opinions best left to the individual. Type in --HYPOID GEAR OILS-- in your browser for a wealth of up to date info0
29 Vic wrote:What is the car you are wish to change the gear oil in?
It's a 48 Commodore Six.0 -
If straight SAE 90 hypoid fluid is what you're after, go to your friendly local Ford dealer's parts department and ask for a gallon of Motorcraft XY-90-GL. It costs about $35.00. Good luck.0
NAPA or any other parts store has what you need. If you don't see it, ask.0
