Help needed to identify.
Can anyone help me identify a couple of ring and pinions I have in my stock of Hudson parts.??
Markings as follows.
Part Number 307564
18519
45-11 teeth on ring and pinion.
A couple are marked Dana and a couple are marked Salisbury.
Also.. 308525
Salisbury.
41-10 Teeth.
No part number on this one.
Salisbury.
50-11 Teeth.
Thanks in advance.
Les.P.
Part Number 307564
18519
Also.. 308525
Salisbury.
41-10 Teeth.
Salisbury.
50-11 Teeth.
Thanks in advance.
Les.P.
307564 - 1952-1954
398525 - 1953-54 Jet
Both "P" type (Bolted Cover)
Don't have a rear axle ratio list to hand, so don't know what the other one is.
Alex Burr
HudsonTech
Memphis, TN0 -
Les, as far as I can ascertain, the only diffy that had 11/50 ratio was the '52 onwards Dana (P type). Used as standard on overdrive equipped cars. The same overall ratio was fitted to the earlier models, but they were 9/41. That 18519 number doesn't ring any bells in my library! Hope this helps. Best wishes,
Geoff.0 -
45/11 = 4.08 to 1, 41/10 = 4.10 to 1, 50/11 = 4.54 or 4.55 to 1.0
Thanks guys for the info on these Ring & Pinion sets I have in stock, they are for sale if anyone needs one or the other.$49.99 a set plus postage.0
