1951 commodore custom
I just traded for a 1951 hudson commodore with a 302 ford v8 c4 transmission.The car has a 4:56 gear.I was wondering what is the best way to get a higher highway gear.Should I replace the rearend with another ,and what will fit? Or should I just relace the 3rd member and what will fit??
Thanks I am a chevy guy and this is my first hudson.I love it and can not wait to cruise it to Goodguys
You don't say what rear end you are running, but I would think the easiest route would be a third member or gear change in your current rear end. Are you using a Ford 9"? These cars are notoriusly hard to fit rear ends to, so if you've got one that already fits, my suggestion would be to change the gears. Any pics?0
If you have the stock rear end, and the 302 is stock or close to it, I would look for a good 53/54 Dana 44. This would be a direct replacement and not cost a fortune. Not to mention that if you desire to change, many different ratios are available for the Dana 44.
Bob0 -
Just look for a Late 52 thru 54 Hudson Dana 44 with an automatic and it should have a 3.08 ratio.0
You have a lot of good suggestions posted..Hard to believe someone put a 4.56 behind an automatic.. It must feel like driving in Lo Range unless it has real tall 33" Rubber...However I agree with jsrail if the rear is in good shape along with the brakes, wheels, & tires, consider changing your present Ratio into the low 3's (3.08 to 3.42). If its a removable carrier you could pull out the center then take to a local Drive Train Shop to switch the Ring & Pinion. If its an Intregal Rear you would need to drive the car to the local Shop... Regardless of type of rear, The Shop probably would have it in & out same day if the Gears were in Stock....0
Another good option that would keep the peppiness of the car, and not cost much more than a gear change would be to find a AOD transmission and put that in. You would have a over drive then. I think it would bring the gearing right into the sweet spot.0
- 182 The Flathead Forum
- 611 Vehicles
