35 Terraplane engine copartment measurments
Guys; I need some help. Could someone with a 35 Terraplane Six please measure the clearance behind the engine(from the block to the firewall) and in front of the engine(from the front of the block to the radiator and from the fan to the radeator) I have a 35 with no engine and I am trying to fit a Jet engine in it for the time being, until I can get a good 35-37 engine. I don't want to cut up the car to fit anything in there because I want it stock when it's finished(well almost stock). I want hydrualic brakes and a 37 engine.
Hope some on has some help on this hairbrained idea. Thanks
It's doable with not much trouble. Rather than going over it here. Email me thru the forum and I will explain it to you there. Several thing you need to look out for, being you will be using later model parts. 37 on>.0
