Bolt Pattern size ? ?
Forgot what the dimensions are regarding the bolt patten spacing on the Hudsons, what Ford and Chrysler wheels do I need to look for again ! ? ?
If I remember correctly, Ford pick-up's don't inter-change with the Hudson, but several of the passenger car models will. I need to know the models to look for, Chrysler's model's also !
thanks for any help !
The bolt pattern is 4 1/2 spacing , thats standard on Chry. cars up into the late 80s, except the older Imperial, 1/2 ton Dodge PUs except some of the 4x4 ,used that pattern from the early years up into the 90s at least, this pattern includes alot of Ford cars and AMC cars too. a hole for the Hudson line up pin will need to be drilled in most wheels . that gives alot of options for wheels0
Half-ton Dodge trucks went to the 5-on-5-1/2" inch (same as Jeep, Ford PU) FROM the 5-on-4-1/2" pattern in the 1985 model year.
What you MUST look out for is the register (center) hole size - on Fords, it is SMALLER and therefore their wheels will NOT fit a Hudson properly.
Mopar (as described above), AMC, & Studebaker wheels DO work on the Hudsons.0
