54 Floor Pan
Try Bill Albright at (909) 823-9168 or albrighthudsons@msn.com0
I installed the floor pans being offered on e-bay for $69.95 per side and they worked very well with minor tweeking.0
Do you want them to look like original or do you just want to fill the hole? Also, do you need the little piece that makes the corner round (under the carpet)?0
Iwould like it to be original what is the corner piece0
I can make you original looking style. As for the the curved piece, it goes in the corner to make the carpet round, right at the transition from the step plate to the floor. By the way, You need to reuse the old clips that hold the tranny cover. I can't find new ones of those anywhere. Their 'IS' a trick to getting those off without breaking them.0
Here are some pictures of the original pieces from a 54'. These are the rounder corners and what I had for a pattern for the driver's side floor board. The picture with the screw driver is showing how to remove the clips WITHOUT breaking them. Just "lightly, very lightly" tap on the 'small' tab, not the big tab, and they will come right out without bending or breaking. Tap them at about a 45 degree angle, just like the photo. At this time these things are worth their weight in gold.:D ...Can't find new ones anywhere.0
Okay, had troubles with the size of these photos for some reason. But, this looked like it worked, the first picture shows where the rounded corner would go in relation to the floor board. Now I don't know which cars had these, 54' only?? Only some 54's?? Anyone know?0
