Transmission part needed
I am looking for PN 305089, Main drive Gear. Or commonly called an "Input Shaft". Fits late 49 through 52 "R" type, single lever transmission. Either very good used or NOS. have a good OD transmission that has a messed up tip that goes into the pilot bearing. It's probably easier and cheaper to replace the part than to remove it , have it built up and machined.
Super D, you might check with Al Saffrahn if you've not already. Al rebuilds a lot of standard trannies.0
