Coil Question....Help!
junkcarfann
The coil was replaced 2 years ago (2000 Chevy Astro Van, 4.3 engine).
Question....Are coils like light bulbs, i.e. they work or they don't, or can a coil fail, yet still have a tiny spark?
Thanks in advance for any help.
Too new! LOL!
--Jon0 -
What you described is the classic symptom of a bad condenser.0
Yes, a coil can go bad and still produce a tiny spark. Shorted turns is one failure mode that would produce such a result. If you have a shop manual for your Astro Van, they often give the resistance of a good coil and with ohmmeter you could check out the coil. Otherwise, try substituting a good coil. Another part that can cause this is a bad ignition module. As far as a bad condenser goes, his Astro Van has electronic ignition and does not use a condenser or for that matter points.0
