how do you remove old running board rubber
bellbigdawg
getting ready to do the running boards on my 41 bigboy, original rubber mats cracked and a few chunks missing, but seem to be glued on good. how do you get the old ones off??
A hammer and a sharp wood chisel works real well!!0
Took mine off the Terraplane with a flat sanding flap wheel on the grinder till I got close and took the last with a wire brush on the grinder. MESSY !! Did it outside with a resperator and eye goggles. Bud0
A Little Heat On The Bottom Makes The Job Twice As Fast, Bill A0
I had no problem taking it off. I had the kids chip it off,
thanks!! lots off tips here!! would soaking in kerosene or something help?? god this stuff is stuck on there!!0
HI, if its held on by a contact adhesive, you can use a good hot air blower at a couple hundred degress + this will reactivate the glue or you could use acatate (nail polish remover) but you would have to be very careful of any single pack paint, its ok with 2 pack painters though
we do this at work when we lay down laminates etc and they arnt straight enough
Mike0
