Plaster Hudson
[Deleted User]
edited November -1 in HUDSON
Found This On Ebay---item #120297511153, Somebody Thinks They Really Have Something. Maybe Someone Can Post The Item On Here
    http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=120297511153&ru=http://search.ebay.com:80/120297511153_W0QQ_trksidZm37QQfromZR40QQfviZ1
  • rambos_ride
    rambos_ride Senior Contributor
    It's a pretty detailed casting - maybe this is something authentic?
    .The designer's name was Mr. Heffilinger
  • The seller is pretty proud of it, in any case.
  • Jon B
    Jon B Administrator
    Though it may indeed be a styling plaster, it's possible that it's a copy. It might be that someone made a mold of an original styling plaster and then created one or more copies of it for bigwigs in the company. And certainly, in the 70's or 80's, there were resin copies floating around in that large scale, most of them "in white" (ready for painting by the buyer). This Ebay one appears to be real plaster but again, it may or may not be an original Hudson styling plaster.
  • 53jetman
    53jetman Senior Contributor
    If you look at the front end picture, you will see that is a 1950 Commodore, not a 1951 Hornet. It appears the seller has received some bad information somewhere along ther line..
    Jerry
    53jetman
    Jerry
    53jetman
    Bad information.... Yeah, like the fact that the seller was somehow lead to believe that it's worth thousands of dollars? I think most people with thousands of dollars to spend on a Hudson want one they can drive.
  • Aaron D. IL
    Aaron D. IL Senior Contributor
    I've gotten a few driver Hudson's for under $5K that the guy is asking for that plaster model. However it's he could document it and prove it's historical authenticity it might be worth that to a collector. Especially since a lot of Hudson's design and development stuff didn't survive.
  • RL Chilton
    Amen to that. 5K would be a lot of parts . . . or even a whole car!
    I agree. After all, they're not making Hudsons or parts anymore. At least with a car and/or parts, you can use them or just look at them if you like. No choice with a model.
    But as Aaron says, the model would have worth to a collector if it can be documented as a legitimate Hudson styling model. Since Hudson (like all other manufacturers) had departments that built clay styling bucks (which were usually full sized), I don't see what purpose a painted plaster model would serve, especially since the design was already old at the time.
  • Sarah Young
    Sarah Young Senior Contributor
    Ypsilanti Heritage Museum has a plaster model of a Jet that I was awestruck by. It was definately not painted.
  • Sarah Young
    On second thought, I think the body's painted Surf Green or Spring Green.
